Distance from dimension line to text/numbers adjustable?
Is it possible to adjust how far the text/numbers are above the line in a dimension style? I didn’t find where this is possible…
the option is called “text gap” under fonts in the annotation styles in your properties
here a screen shot from the mac version.
also just in case, you can at any time activate the points and move it manually.
OK, thanks, I tried that and I thought it wasn’t working because initially I had tried with too big a value and it made everything go crazy… But something is definitely buggy:
Gap standard 0.8:
Works fine increasing it by tenths to 1.1:
Hit 1.2 and this happens:
:roll_eyes:
I filed a bug report… https://mcneel.myjetbrains.com/youtrack/issue/RH-83402/Editing-text-gap-in-dimension-style-blows-up
RH-83402 is fixed in Rhino BETA
