Displaying selected elements takes too long
The following applies to Rhino WIP using Direct3D.
It’s more or less the same with OpenGL, and it’s the same in Rhino 8.
There is a file with ~300000 flat curves.
The display performance is excellent when zooming etc..
But not when the curves are selected.
Or when we select one curve by a single mouse click.
The video shows the effect using TestMaxSpeed:
Unselected: 2sec.
Selected: 43sec.
I wonder why yellow elements take so much longer to display?
We can feel the lack of speed when we select an element by mouse click.
There is a notable delay until the element is yellow on the screen.
1sec.
And it takes the same time when we unselect by click into nirvana or ESC.
Makes me think the identification of the element is super quick, but not the display.
When I try the same geometry in Rhino 1.1, select/unselect has no delay at all for a single element.
It shows in yellow immediately.
(The general display performance of V1.1 is of course not on the same level as in V8/WIP - no wonder.)
@jessesn says it’s because the sheer count of objects.
300k curves isn’t that much!
Rhino 1.1 show the reaction w/o delay.
Rhino 8+WIP feels and is slow in this regard.
This is a DXF V12 Lines+Arcs:
2025-12-04_Yellow.zip (9.8 MB)
Also see:
And how Rhino 1.1 feels:
Thank you for your report, and I have logged this issue with our development engineers.
RH-90869 Display: Displaying selected elements takes too long
Damn, having Rhino 1.1 is so cool. :smiley: I wish I had it, too.
RH-90869 is fixed in Rhino WIP
IMO this is NOT fixed.
Selecting is still super slow.
Dragging selected elements is no fun.
Yes, TextMaxSpeed slows good figures.
Working with such files is different story.
Not that I’m qualified to add any thoughts here at all, but one major difference between Rhino1 and Rhino8 that crossed my mind when reading this thread is history. When was history introduced in Rhino (according to Gemini, it was introduced Rhino4)? And I wonder how this file reacts in Rhino7 compared to both Rhino1 and Rhino8.
[edit]
And does performance of this issue improve any if history is turned off?
Also, I can’t even make 300,000 curves on my computer, which, it’s not a very good computer, so that’s not surprising. I can make 30,000 rectangles and my computer struggles a bit, but once they are there, selection is not noticeably slower. But attempting to make 300,000 rectangles (with the array tool) just seemed to make my computer endlessly do nothing, so I had to ctrl-alt-delete and end the Rhino process. I mean maybe if I waited 5 or 10 minutes it would have made them, but I didn’t want to wait.
Does it get better when you close the properties panel?
Hello @Charles
Unfortunately, there isn’t really a solution to this problem. As soon as you notice a performance slowdown in the 3D view, you can be certain it’s due to data transfer between system memory and GPU memory via PCIe. For some unknown reason, Rhino constantly updates data on the GPU (especially during selection), even when you’re simply moving the 3D view.
The only relatively effective solution is to limit the number of objects—whether curves, surfaces, or meshes.
For example, many real-time rendering programs like Unreal or Twinmotion offer features that allow you to combine all objects with the same material into a single large object. This is simply a trick for batch data transfer; it’s better to have one large mesh than 1,000 small ones. (You must also take into account the data regeneration time. This time cannot be faster than the speed of your processor)
Bref, in your file, each straight line is a separate line. The most effective solution is therefore to merge your lines.
with Rhino 7:
Your file also contains identical and redundant lines. If there are many of these lines, removing the duplicates will further improve performance.
Oh yes, and video capture uses a bit of PCIe bandwidth. But I’ve split the video, so at the beginning you can see the bus usage with recording enabled.
I think there is a solution, perhaps not yet in Rhino.
Other (well-known) apps can handle such cases with ease.
I can’t see that in here, Bus Interface Load is near 0.
Recording using Camtasia doesn’t show the truth, it cranks up the GPU clock and uses ~12% bandwidth.
Without recording it is ~0-2%:
That makes it easier to handle large data sets.
Large meshes in Rhino work good in Rhino.
I don’t want to work with this file, I want to demonstrate a problem.
Rhino is excellent for dimensioning and layouts.
What’s really missing is the same level of performance as in the other well-known app, which is widely used for plans.
If Rhino can compete, it’s more likely to be used as an alternative.
Okay, it’s still strange that the bus isn’t being used at all…
And yes, the first version of Rhino really did work very quickly with large imported AutoCAD files.
Hi Charles -
The YT item was reopened → RH-90869 Display: Displaying selected elements takes too long
RH-90869 is fixed in Rhino BETA
I’ve thrown that upon the pile as INF-647 Bozo: Finding Fixes for Disco
I found that the reason for the slow selection is that there are too many very short curves in the scene. When I use SelShortCrv to select and found 353,122 curves shorter than 1mm, and then hide them, selecting objects became very fast. The situation is as follows, for your reference.
everytime I import autocad files to rhino, I do _seldup to delete thousands curves and _setpt (I select Z axis) to make all 2d drawings on Z axis, make sure they are not in 3d.
That makes my Rhino works so fast.
I think most autocad users do not much care if there are duplicated curves, short curves or 2d drawings beyond Z axis, no offence maybe I am wrong.
Nice idea, but…
Curve count before SelShortCrv: 447710
After: 89784
Only the count is reduced, and the lower the count the less lag is there.
It has nothing to do with the curve lengths.
Also, when the short curves get deleted, essential parts of the drawing go away:
The problem still persists, and IMO it’s an important problem.
In my tests, after using SelShortCrv to find and hide curves shorter than 1 mm, selecting the remaining curves becomes very fast.
For some important curves that need to be kept locally, you can Lock them before running SelShortCrv. I hope this helps you.
That is correct, except the very, it’s an acceptable speed.
No, that does not help, because I don’t want help with this drawing, it’s not even mine.
Around 500.000 elements in a drawing is not that much!
Even Rhino 1 could handle it.
There are performance problems in Rhino with such counts.
Your proposal is to fix the performance problem by reducing the count.
This is cheating.
And not a fix of the root problem.
