There are three ways to display text in the viewport, depending on what you want to do:
- Use ‘Text Tag’ (2d tags), which seems like what you are trying to achieve when I look at your screenshot.
- Use ‘Text Tag 3D’
- Use a plugin or script that converts text to curves and/or surfaces. The ‘TextCurves’ component from Squid should work, what problem did you experience? There are different options, but we usually share the script below which does both and provides many options for the font.BakeText.gh (20.0 KB)
