I am trying to create a display mode for axonometric details, which is a cross between the standard “Rendered” and “Technical” display styles. Basically need everything in Rendered but with options for Hidden lines and Silhouette lines. Is this possible?
The objective is to add light surface textures to the objects in the detail drawing to distinguish materials.
you can also stay in technical, and use SetObjectDisplayMode on each object you want to show textured, just be sure that you have shadows turned on and lighting turned to ambient occlusion for instance which will give you the the results shown in your example.
i have SetObjectDisplayMode set to shortcuts because i often switch objects for modeling purposes like that when just one object has to change.
