Does anyone have this type of issues with the viewports ?
Does anyone know how to fix this problem ?
Hi @jperez5
First thing to do is to run the SystemInfo
command in Rhino and post the resulting text here in its entirety - that should give an indication of what might be wrong. Judging from just the screen shots, I’m guessing an outdated graphics card driver. Make sure that you are running the latest graphics card driver available, latest Rhino Service Release and latest Windows version.
HTH, Jakob
Actually I just updated the drivers to the latest ones… i was using an old one, which it appears it is the last one that works…
It started to do this when I updated the drivers…
And I have the latest Windows 10 version, with the latest update and the latest Rhino Service realease…
It might be a 3rd party plugin, it might be a botched driver installation, it might be the full moon or an evil hex - run SystemInfo
and post the result.
-Jakob
it is not the first time that happened to me… but i try to update the drivers again today and happened again… i’m hoping this time i get to the problem…
Hi @jperez5
I’d start by updating the Intel driver, which is a little old. If that doesn’t work, try to disabe all the 3rd party plugins and see if it helps; if it does, then enable the one by one to see which one is the offender. It might also be worth checking out this post if you haven’t already
HTH, Jakob
Thanks, by the way in Safe Mode the problem goes away…
I can’t update the Intel Display driver because it appears the one i have is the last one compatible with my laptop…
