When I have a closed poly surface selected, in the object properties. Some of the icons are missing. Such as Displacement and Edge Soften.
Hello - it looks like Vray is the current renderer - make Rhino Render current and you should see different stuff⌠any luck?
Hi Pascal,
the current render is set to rhino and still no luck.
I thought VRAY might be the problem so I disabled VRAY and restarted Rhino with it disabled but still no luck.
P
Hello- can you please look in Options > PlugIns page for the RendererDeveloperKit plug-ins (two) and make sure these are enabled and loaded?
Hm⌠and just making sure - your selection there is what, to get that set of icons? A brand new file with just a box made and selected⌠same?
I have also uninstalled 7 and reinstalled it to no prevail.
Got it, thanks⌠I do not know- can you please run SystemInfo
in Rhino and copy/paste the results here?
Also, please check in Plug-ins for the âDisplacementâ plug-in - is that one enabled/loaded?
Brilliant!!!
the Displacement plug in wasnât loaded.
Thanks
OK - great⌠still trying to figure out why, thoughâŚ
Rhino 7 SR5 2021-3-23 (Rhino 7, 7.5.21082.11001, Git hash:master @ 944c103dcfd368bc1974c8866461f0c7bf5ae9d3)
License type: Commercial, build 2021-03-23
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Users\patri\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Crayon (43f0446f-00a7-4ff3-864f-0d3af5e47e2b)\1.0.7750.23916\Crayon.rhp âCrayonâ 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp âV-Ray for Rhinoâ
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp âWebBrowserâ
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp âRhinoScriptâ
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp âRPCâ
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp âAnimationToolsâ
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp âIdleProcessorâ
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp âAlerterâ
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.5.21082.11001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp âNamed Positionâ
