Disable right mouse button repeat workaround
Despite posts from myself and others asking for the ability to remove “enter” from the right mouse button, there is just stony silence from McNeel. I use a wacom tablet, and it is just far too easy to fire “enter” when all you want to do is rotate the view. Its also too easy to do this with a regular mouse also.
Anyway, I wont go into it again because I’ll just get all upset, but in the meantime here is what i have done to get around it, in both V6 and V5:
disable right mouse button V6:
options, advanced - scroll down to entries for right mouse button.
Set:
rightMouseDownRemap to 1
rightMouseMoveRemap to 1
rightMouseUpRemap to 1
This disables the right mouse button (except for selecting via a crossing window & maybe something else I haven’t come across yet). I have no idea what this actually is supposed to do since I can find no help on it, but for the moment it seems to work to disable the button.
Now, in options, mouse, set the middle mouse button to manipulate view rotate.
This gets the middle mouse button to rotate the view, as the right mouse button previously did.
Finally, in the Wacom properties, set the secondary pen button to middle click. This allows that button (previously assigned to the right button) to rotate the view as before, but without firing off enter all the time.
It unfortunately also sets it to middle button for every other program…but I use rhino more than anything else, so I just have to live with it.
In V5:
There isn’t an advanced set of options, but something similar can be done by just setting the middle mouse button to rotate the view, then altering the wacom properties as above.
The other way to probably do this is to open the mouse and physically disable the right button permanently, and then use this mouse for rhino only. This has obvious problems if you are going to multitask with other programs on the computer but I was so annoyed that I was going to do that very thing if the above hadn’t worked.
The whole situation is ridiculous - why should i have to go to such lengths to try to configure my computer and my copy of the software to work how I want…??
I’ll ask one more time again: Please give the user the option to disable “enter” on the right mouse button.
cheers
rabbit
Thanks Rabbit, I will look into this. I did have some success damping down the effects by slowing down the click speed on my mouse, using the Windows mouse control settings, but it still happens, and of course now using my mouse feels like trying to write while wearing boxing gloves!! I will fiddle around with the click speed settings to balance this a bit less but you are dead right, the option should simply be switchable. I see know utility in the option anyway, other than to irritate users like you and me! At which, it is extraordinarily effective!
Anyway, thanks again, I’ll report back when I have had a play…
Hi Tony - I added your comments to the bug/request item.
thanks,
I agree it would be nice to disable RMB=enter, but many users have just been so accustomed to this functionality for so long we haven’t made a fuss. Nearly 20 years in Rhino, and then in Autocad before that. True, we could disable it in Acad, but we didn’t because it’s a timesaver.
Oddly just tonight I started having a major issue with it while trying to pan around. Took me 10 minutes before I figured out my wireless mouse batteries were dying and was causing a lag between click and drag.
EDIT: OK mouse was not the problem. This is now messing me up big time. I have no idea what has changed with my setup after years of no major issue with this. Now can’t do my curvebooleans like I need to. RMB is activating enter prematurely while panning.
I’m continuing to troubleshoot…
Hi, thanks for this! It solves the issue on windows, however, can I disable the command on mac as well? I’m working on two different machines and it drives me nuts on both.
Thank you!
Kama
I’d also like to see a way to disable this in macOS. I’ve been bitten by this often while rotating the view and picking edges.
Thanks!
Placing 0 (cero) to the "Context Menu Delay " has solve this for me, now i can have the context menu and use the middle button for pan etc
Thanks rabbit! This has been bothering me for a while now. I am working on a plugin that requires that I select some vertices on a mesh. I would be continuously kicked out of its execution because I wanted to rotate my view around to select more points. At first I thought I was coding something wrong on my end, but it turns out this has been an ongoing issue.
When it came to V6 (on Windows 10), I was able to disable the “enter” functionality using your idea by Setting:
However, I left rightMouseDownRemap alone. This leaves the rotate/pan functionality with the right mouse button, without having the frustration of accidentally “entering” with the RMB.
Let me know if this helps at all.
Robert
There should be an option to disable it, but if RMB = Enter is removed from Rhino, I swear I’m gonna murder somebody. :smiling_imp:
yeah - thanks robert.
so this seems to be the way to do it with V6 - (I’m on windows 7 so I think any version of windows that will run V6 is ok.)
rightMouseMoveRemap - 1
rightmouseUpRemap - 1
rightMouseDownRemap - leave at default
which cleanly seems to disable “enter” being called by the right mouse button.
Who knows if this is really correct or there is a better way? - All I can say is it seems to work without any side effects so far…
As for V5, there is no other way to get around this I have found except that offered in my original post.
cheers
rabbit
Maybe things have changed since this thread was started, but it seems like McNeel are at least aware that the default behavior of RMB is an issue for some people. Here is what the current help file has to say about it:
Right mouse button
Delayed context menus
Displays a context menu with right mouse button click, hold and release in a viewport.
When this option is unchecked, a single right-click displays a context menu, and will not repeat the last command.
However, this is not how Rhino 6 actually behaves. If that box is unchecked, it simply suppresses the context menu altogether – so it never shows up, regardless of how long one keeps RMB pressed.
So there is clearly a mismatch between what the manual is saying and how the application is actually behaving. In other words: Either there is a bug in Rhino 6 or there is a bug in the documentation.
@KelvinC Re: Help documentation
This was a change in RH-49030 for v7. The change was reverted in RH-49539.
I made a mistake to show the description in the v6 help topic. I’ll delete the description in the v6 and v7 help topics.
Thanks.
Thanks for clarifying, @KelvinC
While you’re at it, I think it might make sense to add a note to the help topic, pointing out that this behaviour (i.e. RMB immediately displaying the context menu instead of repeating the last command) can be achieved by setting the delay time to 0.
Quite a few people seem to be looking for this option.
@c.schmidt fyi– If you choose to not use Reply, then you can type the @ character followed by the first letter of the person’s first or last name. The autocomplete list should show a choice of respective members to alert them to your post, hopefully getting you a timely response.
@c.schmidt,
The topic has been updated with the note, thanks.
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#options/mouse.htm
@robert.beck12569 that method worked for me thanks it was driving me crazy!
I tried to use another mouse and it helped for me. Apparently a small hesitation/fail of your mouse RMB can cause all these frustrations…
Chiming in as another user quite bothered by this. The rmb seems to always repeat the command after I rotate… It wasn’t an issue for me until recently; not sure why.
@Sean_Lamb Same here. This wasn’t an issue for me until V7 and now it’s crippling my workflow with interruptions. Rhino 7 feels eager to jump at the chance to repeat the last command when in versions 4-6 I don’t remember this happening. I sure would like a chance to return to the old days of Rhino not interrupting my mouse behavior. Any response from McNeel besides the context menu hack?
