DIR bug after SwapUV
Bug where clicking UReverse or VReverse after SwapUV reverses the wrong thing.
To repeat this bug:
Select the surface
DIR command
SwapUV
UReverse
V gets reversed instead of U.
swap and reverse bug.3dm (170.4 KB)
Thanks! The result of the U reverse is correct if you run Dir again so I think the bug is with the preview for Dir… filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-43623
This is happening in R8 SR16 when _Dir is used with multiple surfaces selected.
On a single surface, everything is correct.
With multiple surfaces selected, the display is broken but the actual result is correct as described above.
