if I SwapUV per _dir than the UV arrows swap, but the texture is still like before. The mapping mode is “surface” and the texture should swap.
-Micha
Swap UV not working.3dm (191.6 KB)
-Micha
I found now that _RefreshShade fix the display issue. So it looks like it’s a bug and could be fixed. ![]()
Still needs to be fixed. ![]()
Please don’t forget it. It’s still broken on Rhino 8.
I think you are the community member with most Patience dealing with rhino and chaos group!
I use Rhino and V-Ray for rendering daily - I’m a 3D viz freelancer. ![]()
Such a small bug can’t be fixed?
