I want to rotate the orientation by 90° is this possible? Thanks!
Hi Hannes,
select the surface to flow to then run the _Dir command. You then have options like _SwapUV _UReverse and _VReverse…
c.
@clement never thought of the parameters in ‘Dir’ command! Thanks!
But actually a feedback like UV arrows (green/red) in UV-direction are missing. So when I’m firing UV_reverse or Swap I would get no feedback at all. What do you thinK? H
cool!
