Dimension Text Size Won't Change
Version 6 (6.23.20055.11282, 2020-02-24)
Changing Height Parameter does not do anything.
Screen Shot 2020-03-11 at 9.32.16 AM
Hi - could you provide a 3dm file and step-by-step instructions of what you are doing and seeing?
I have encountered a lot of funky situations like you describe with styles. One way I have found to get around such a problem is to modify an individual text object. Then use the option to apply the objects formatting to the style.
