In the latest WIP release (8.0.23024.12306, 2023-01-24), it seems like the dimension commands can’t be repeated/reinvoked by hitting Enter. Instead a previous command is repeated, in my case a rectangle is drawn. I didn’t try all dimension commands, but at least Horizontal, Vertical and Aligned Dimension seem to be afflicted by this.
Update:
Here’s proof:
Unfortunately, keystrokes aren’t recorded by the screen capturing software, but I hit Enter right after the dimension command has completed.
Command: _Circle
Command: _Circle
Command: _Delete
Command: _Circle <--- PREVIOUS COMMAND
Command: _Dim
First dimension point ( AnnotationStyle=Millimeter Small Object Continue=No Baseline=No )_Continue=_No
First dimension point ( AnnotationStyle=Millimeter Small Object Continue=No Baseline=No )_Pause
Second dimension point_Pause
Dimension line location (offset distance) ( Horizontal Vertical )_Horizontal
<--- ENTER HIT HERE --->
Command: _Circle <--- REPEATED PREVIOUS COMMAND
Please note that I kept Rhino running over night and it has been open for about two full days now.
Here’s my SystemInfo:
Rhino 8 SR0 2023-1-24 (Rhino WIP, 8.0.23024.12306, Git hash:master @ 036f76afc2fd6926adb81ca67cbe460a4210c0e8)
License type: Educational, build 2023-01-24
License details: Cloud Zoo
Expires on: 2023-03-10
Apple macOS Version 12.6.2 (Build 21G320) (Physical RAM: 64Gb)
Mac Model Identifier: Mac13,2
Language: en-LU (MacOS default)
Apple M1 Ultra (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 48 GB
Graphics: Apple M1 Ultra
Displays: Unknown (108dpi 1x)
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Ultra
Thunderbolt Display (2560 x 1440 @ 60.00Hz)
USB devices
Apple, Inc: Apple Keyboard
Apple Inc.: Apple Thunderbolt Display
Apple Inc.: FaceTime HD Camera (Display)
Apple Inc.: Display Audio
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp "RhinoRoslyn" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp "Constraints UI" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp "RhinoCPython" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.0.23024.12306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 8.0.23024.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23024.12306
Update 2:
The bug persists in 8.0.23031.14306, 2023-01-31.
