gszechter
(Gonzalo Szechter)
June 23, 2020, 2:41pm
1
Hello, just reporting a bug here. When working on 2D drawings at some point _Dim command bugs and starts repeating itself when when using “Left click” instead of confirming and finishing the command. After drawing the dimension line I can press “Right Click” to stop it but it is annoying. This just happens randomly no matter the file I’m working with, it restores to normal by restarting Rhino.
It’s been happening since I installed Rhino so it’s not a new thing, I just hadn’t got the time to report it.
I recorded a video if you want to check it out.
Best Regards,
Gonzalo Szechter.
wim
(Wim Dekeyser)
June 23, 2020, 3:24pm
2
Hi Gonzalo -
I’m only seeing this:
Could you run the Rhino SystemInfo command and copy-paste the result here?
gszechter
(Gonzalo Szechter)
June 23, 2020, 3:49pm
3
I think I fixed the video privacy settings, now you should be able to watch it.
Rhino is not bugged in this precise moment, do you want me to run it now or when the bug comes up?
AlW
June 23, 2020, 5:48pm
4
It should be the same either way as it’s a report of hardware and certain installed software.
gszechter
(Gonzalo Szechter)
June 23, 2020, 8:26pm
5
Rhino 6 SR26 2020-5-26 (Rhino 6, 6.26.20147.06511, Git hash:master @ 7788f6214ee9335d5793cc6177985a1c745e663b)
License type: Educacional, build 2020-05-26
License details: Cloud Zoo. In use by: Gonzalo Szechter ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DESKTOP-GONZA
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 4-3-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 445.87
Secondary graphics devices.
Intel® HD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-3-2020
Driver Version: 26.21.14.4587
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.26.20147.6511
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot8RhinoPlugin (6c7d7caf-b4ba-406d-bfaa-8d719d8212c3)\1.5.0.0\KeyShot8RhinoPlugin\Rhino 5.0\KeyShot8RhinoPlugin.rhp “KeyShot8RhinoPlugin” 1.5.0.0
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.26.20147.6511
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
pascal
(Pascal Golay)
June 23, 2020, 10:13pm
6
Hello - looks like Continue=Yes at the command line - I cannot tell what button you pick but a right click on the dimension button sets Continue=Yes.
gszechter
(Gonzalo Szechter)
June 24, 2020, 3:29am
7
Never saw that command line, I’m kind of embarrassed.
Thank you Pascal, after all you solved what was a major problem for me.
I will erase this post as I think no one will be this lack of sight.
Regards,
Gonzalo.
pascal
(Pascal Golay)
June 24, 2020, 3:02pm
8
Hi Gonzalo - no worries, it is easy enough to miss this if you do not know it is there.
egdivad
(DavidGe)
August 6, 2020, 6:39am
9
Started noticing this today, the text overwrite in the property panel takes no affect on the dimension
wim
(Wim Dekeyser)
August 6, 2020, 6:58am
10
Hi David -
I’m not seeing that here.
Please run the Rhino SystemInfo command and copy-paste the result here. Also please post a simple example model that shows this behavior on your system.
gszechter
(Gonzalo Szechter)
August 6, 2020, 3:05pm
11
If you don’t want the “30” to appear just erase the “<>” signs. Then, if you want “Edge distance” to appear next to the dimension try checking if a letter o a smaller word works out, so in that case it should be an issue coming from the amount of characters written in the input.
