Dim settings
changing the properties of the dimensions, even if creating a new dimension style, brings the application in confusion. After a while i’m not able to change the numbers in the various fields, and the application goes into loop. I’m also not able to close it. Happens every time, so definitely a bug.
To produce it just start applying a dimension and start changing the settings for the dimension style.
I’m afraid I’m unable to reproduce this bug with the description provided. It sounds frustrating. Can you please provide very detailed steps for reproducing this behavior.
seems that this behavior is gone with the new release.
I’m not able to reproduce it anymore.
Thanks
