Is it possible to have different line widths for the outline of a wall and the hatch that’s inside?
Hi @meital875,
No, this is not currently possible. Section outline will use the “Section Print Width”, but the hatch will use a default hairline width. Do you want to also specify a line width for the section hatch lines?
Enric
I tried changing only the width of the section outline, but for some reason it changes also the width of the hatch.
Hi @meital875 the “section print width” attribute of an object should not affect the thickness of the hatch pattern it uses when it is shown in section. If that happens, please send the model to visualarq@asuni.com. Also make sure you have the last VisualARQ version.
