If I choose a hatch pattern made of lines for an element in a paramteric Va object, what determines the lineweight?
Hi @djhg the hatch pattern used as section attribute always uses a “hairline” line weight. Would you like to edit that line weight?
Yes please.
It would also be good if the hatch scale could be set to display and print the same regardless of the scale of the detail view.
On, marked.
You can do this with the Toggle Hatch scaling in the page layout.
That’s a really handy thing to know. Thanks.
