I have a question about a command in Rhino software, specifically the ApparentIntersections option in the Trim command.
As far as I understand, when ApparentIntersections is turned on, it allows for objects to be trimmed even if they don’t intersect exactly. However, when I turn it off, I am still able to use objects that don’t intersect in the Trim command.
Determines whether or not curves are trimmed in relation to the view. They do not need to intersect in 3-D space. They only need to appear to intersect in the active viewport.
This option does not apply to surfaces.
after applying _split, the resulted fragments are selected. deselect the part(s) you want to keep.
ctrl click (pc) or ctrl select rectangle
cmd click (mac) or cmd select rectangle
