i can’t trim overlapping lines and I can’t explain it why. It have happened before too.
Can anyone suggest something I should try?
Thank you,
Anton
Thank you,
Anton
Hi Anton - if the overlap is ‘apparent’ and the curves do not actually intersect in space, set ’ApparentIntersections=Yes'
in the Trim command line options.
Thanks Pascal,
This worked perfectly. Just out of curiosity, do you know why that happens from time to time?
Hi Anton - I can only surmise that you may have needed that off at some point and set it to No… do you think it’s not from your setting it?
It is very likely but I had to have done it by accident because I don’t know how that option is used. I won’t forget to check on it from now on though
