Trim: ApparentIntersections not UseApparentIntersections
When I use the Trim command it includes the command line option ApparentIntersections
Help lists the option incorrectly as UseApparentIntersections This is confusing. Trim | Rhino 3-D modeling
Personally, I think UseApparentIntersections is more suggestive of what the option does, so if changes are made I think the option name should be changed to match the documentation.
Yep, got that, thanks.
RH-66139 Help: Trim, ApparentIntersections
I can’t find any record about the option name change. It is fixed now. Thanks.
I chose to change the help topic because changing the option name in the command may cause compatibility issue to existing scripts. Thanks.
