I have a question regarding line print widths, specifically the difference between a certain layer’s “Print Width” and “Layout Print Width”. See here.
I initially thought that if I print from model space (top view) using a “window” from “view and output scale” area, that “Print Width” will take the precedence and the drawing will print out in that certain thickness. In my example, I set the “Print Width” to be 0.12
On the other hand, if I print from Layout window using a pre-created layout from “view and output scale” area, I thought that “Layout Print Width” will take the precedence over original “Print Width”, so I set this to 2.
However, in both cases, my printed PDF had the same thickness of 0.12.
I left the scaling in both cases to be the same, didn’t change any other options.
I’m using Adobe PDF to print out all of this.
Could you advise if I’m doing something wrong here or am I missing something?
… I also like to have some clarification here … I thought layout print width would kind of override the print width when using a layout… but I cannot get it to work that way…
The help file just says: " Print Width: Sets the line width assigned to the layer for printing only." and " Layout / Detail Print Width: The line width assigned to the layer for printing only. Specify a line width assigned to the layer for printing only or specify No Print…"
So basically the same thing. I notice the same behavior: in a layout tab when I set the print width it automatically carries over to the Layout PW. But when you manually change those Layout PW settings nothing happens (it still prints at the “print width” settings.
The “Print width” dropdown setting in the detail window’s object properties tab doesn;t seem to do anything either.
McNeel, what’s the point of having a “Layout Print Width” setting if it doesn;t actually change the lineweights for a specific layout only?
In think, layout print setting only apply to object created in the Layout Space (pages). Print settings apply to objects in Model Space. Remember, a Detail is a window into the Model World, so the normal Print Setting will affect everything.
