Print Width Surfaces
Super basic question, and can’t believe that I don’t see the setting, but how do you control the print width for surface and polysurfaces edges.I can find where you set if for the display, but it doesn’t affect the actual printed document.
It’s a Layer property or you can set it by object in Properties.
Thanks. It’s working now. For some reason they were all printing the same line-weight even thought I had changes the layer print width and the object print width.
Ah figured it out. the layout detail was set to a techincal view.
