why when I print the line widths don’t match the way i arranged them in the model.
the print doesn’t show thickness lower than 0.1
can anyone help me with this?
on the left is the pdf and on the right is the layout view with print preview turned on.
this doesn’t happen when i print the same document from other computers.
It is a known issue being discussed on this forum, and mcneel is working on it.
Linetype Width and Pattern Scale Incorrect on Layout : RH-78703 (myjetbrains.com)
the line weights are as i want it to be in the layout. the problem arises when I export it to pdf or when i print it.
