Layout print color
Can anyone here explain me the difference between print color and layout print color?
From a brief test, objects with a layout print color assigned (either directly or by layer), will print in that color IF they reside ON the layout (i.e. NOT when they are displayed in a detail on a layout).
FWIW, I don’t use that feature (and line width) but probably would if also geometry viewed in a detail on a layout would act according to those properties…
wim has it mostly correct, where I would add to this is that it also can be applied on a per detail basis. If no details are active, then it only applies to objects on the layout, like wim stated. If you have a detail active, objects in that detail will be affected by the layer’s layout print color and weight if you change per layer layout print color / weight. If you change the print color per object, it is affected everywhere, not just in that detail.
Sam
Thanks, Sam.
That makes sense then. That way it works the like Layer ON/OFF works per detail. Good to know.
