When the process of rendering the files starts, the color changes, additionally, if the file is saved, it saves it in the wrong color, but in another computer the same file works normally.
The following procedures have been carried out:
Update of both video and monitor drivers
Reinstallation of software Brazil
Cleaning hardware and software equipment
Tests with and without a video card
After all the above, the problem persists.
Not sure why you are getting inverted colors. Have you tried with the latest Rhino and Brazil (eval versions should work) to see if the problem has already been fixed?
Solved.
Reinstall the latest version (evaluation) and it worked normally, then uninstall everything related to RHINO and BRAZIL. Perform a complete cleaning of the equipment (records and temporary) and install all the software again.
