I have a problem with my surface; since the surface lines are not straight, when using diagrid plugin, the diagrids are going in zigzag in the Z direction. Not optimal for putting floors on it. What can i do to rework my base surface ?
I posted the new one sorry. But you need to understand the question. Diagrids go in X, but the north and south nodes are going straight so you can put a floor on them. My surface does not allow me to make the diagrids straight. Can i change that ?
Plus if you regenerate the surfaces as ‘nice’ untrimmed surfaces you’ll still face a problem where their edges don’t match up, on top of the old problem of edges not being straight relative to your floors
OK thank you. But i don’t understand why it is that difficult since architects will always need straight diagrids. It is hard to design something from structure to form. I began from form and it should be easy to go to structure, but those damn surfaces !
*Edit/note:
The screenshot shows an example direction for the contour, then mirrored, not necessarily the ‘straight’ diamonds from lunchbox, but you can define said direction to get the aspect you want?
I found a way, i did contour, divided the curve, then connected every point with Relative Items and Shift list to make them go diagonally. Problem; the first Point is connecting also diagonally to the last Point. You can see the arrows on the picture of the lines i want to remove. Basically you can see a facade and behind the facade. Remove the lines behind the facade, any idea how to do that ?
