Detail needs rotation
Often when we work with real north as “up” like here:
we end up having to rotate a copy of the drawing for details like this:
So obviously we need the ability to rotate a detail in layout.
Hi Jørgen,
TiltView should do what you need.
gr, Tobias
Hello @Holo,
Do the solutions on this post help at all?
http://discourse.mcneel.com/t/rotating-a-view-in-paper-or-model-space/32834/2?u=mvyess
Regards Michael.VS
Hi Tobias.
Yes, Tiltview with an accurate Angle does the job as a workaround/hack.
But it is tedious getting it right and far from obvious so I hope McNeel adds a propper option for this.
The detail should have a “tilt view” option/setting too.
Hi Holo,
I asked the same question a little while ago - WISH - Rotate Details
The Ctrl-Alt Arrow Key seems to work better for me than TiltView since I can set the degrees for the camera
I agree a more obvious command that allows you to rotate a view is ideal
-A
Why not set your CPlane the way you want your detail oriented (in detail, obviously) and SetView CPlane Top?.. That’s what I use.
I agree that there are many ways to Rome, but these are “hacks” that has to be remembered and not well integrated and intuitive solutions, or do you disagree?
I mostly agree. But it sounds like a daunting task.
What are you gonna use as a guide to create your view on an object/structure/w/e that doesn’t have 90 degree corners anywhere? What if it doesn’t even have straight edges and you need to show a proper elevation that’s not NSWE?..
Sure it’s a hack, but a pretty elegant one.
I’d rather see a tool where you can line up your details & objects in them to each other without jumping through hoops before that.
Hi Holo, maybe sticking my nose where it shouldn’t but, seems like a logical thing would be to select a (circle, elipse, rectangle) as a way to pick a detail and acts as a snapshot. Then move that to the desired location. Of course you could increase its size after moving. Kind of like when you print something with a window, except movable and zoomable.
I haven’t used layouts much. By the way, nice work on what youv’e shown there. —Mark
Hi!
Interactively tilting the Detail view with ALT-SHIFT-RMB is not really useful, because mostly viewport rotation should be precisely aligned to the drawing, right?
So, TiltView should have an option to rotate in the same way as the normal ‘rotate’ command - by clicking a center, then a start and end angle.
ArchiCAD has this (called ‘Rotate Orientation’).
Thanks!
Is there a certain reason why rotating a detail-view is not working?
I think if we could rotate the views it would make layouting much more pleasant and faster..
best regards,
sebowim
Hi Sebastian -
Details on a layout are like windows in a house. You can look out to the world outside. Turning the window around doesn’t make the world turn around.
You can rotate the view the detail is referencing. Double click the detail to open the viewport and go here:
hello @wim, hello @ShynnSup thank you for your response!
I know that it works like that right now and also know that I can rotate inside the detail, or create a named view with a certain rotation.
I wanted to make a suggestion to alter the behaviour, because it is no real house and no real window - the detail-view could get somewhat of a “direction” that makes it possible to rotate the “picture”. Ofc then you should also introduce some kind of polygonal altering method of the detail-view-frame as well to cater the needs that evolve.
By no means I know how much work this is to implement, but if it’s doable maybe you could add it to your bucketlist. ArchiCad uses this approach as well and it works great to align stuff for studies, plans, whatever.. It would enhance the layout section of rhino in a good way I think.
There are many occasions where you don’t have standard 90, 45, 30, 15 degrees rotations and if there are numerous with “random” rotations and you want to compare certain situations (just one example of many) this makes it super intuitive to work.
best regards,
sebowim
I use this method, but it’s not ideal. Rhino needs a proper way to do this.
I was also frustrated with the TiltView since it doesn’t offer a direct way to click and rotate the view on screen, like the Rotate command does for objects.
So I compiled a small script to rotate a perpendicular view. It works in Detail views as well.
Improvements or changes are welcome.
Best,
Pip
RotateView.py (4.3 KB)
