Detail line questions
Can Detail Lines only be added to Floor Plan views?
Why are lines made into splines in Revit? I am pushing a linear 2 segment curve with 3 control points in Rhino and it becomes a spline with 7 control points once unpinned in Revit.
Thanks,
Dan
Model and Detail Lines should be C1 continus.
I’m fixing it, now it says this.
You can use ‘Explode’ component to split it into segments.
Thanks @kike!
Should we be able to make Detail Lines in Elevation and Section views?
I couldn’t get that to work.
Dan
Hi Kike,
Is there a way to bring in Detail Line Circles from Rhino to Revit?
Thanks
I’m seeing this as well on a circle. Only workaround I have at the moment is to split it.
