Detail Line Tolerance Error
I am trying to setup a radial grid with Rhino Inside Revit. On the Rhino end I have the radial grid and I would like detail lines to show up in the Revit view. When using the “Add Detail Line” component I get an error message that reads:
Curve should be continuous.
Tolerance is 0.1°
Is there a way to adjust this? The detail lines do not draw in the Revit window.
Hi @Set.
The output of ‘Radial’ are polylines use ‘Explode’ to get the lines.
Same for Grids.
You can also Shatter a Curve at its C1 points
