Hello, does anyone have any ideas about adding room separator lines from curves in rhino?
At the moment I’m working on the facades which have to be created from Rhino and pushed into Revit as a generic model, the thing is I have to make those facades compute the room.
I’ve also tried to create those facades as a native Revit elements like walls or curtain walls. but it doesn’t work because the facades alignment is not completely vertical.
So I’m thinking about slicing those facades floor by floor and convert curve into a room separator line.
Thank you for your help in advnace.
