Design of shark skin in grasshopper
Hello everybody,
I struggle to design a shark skin (see image). But I’m a little bit confused and don’t know how I can define this structure in grasshopper. I couldn’t find any tutorial or same structure design in internet. If you have any idea, I would be really pleasure.
Thank you in advance!
Best Regards,
Mertcan
sharp skin.3dm (1.0 MB)
sharp skin.gh (293.2 KB)
Looks like you could use some lofted geometry, and array it along a surface with the ‘orient’ node. A little random scaling based on curvature would probably work well.
If you see the my .gh file, I understood, how I can change skin geometry of a pipe. But I have a problem to define this kind of geometry mathematically. It should also be manufacturable with slm machine :slight_smile:
How can I use lofted geometries? Can you open a little bit, what you mean?
Thank you.
This isn’t going to win any surfacing awards - I probably should have started again with SubD but anyway…
Heres a very quick proof of concept for the shark fin soup- you could improve it with some scaling of the fins (maybe based on curvature).
I had a look at your script, I could not see what you were trying to achive. Anyway, script attached;
Shark Fin Demo.gh (24.5 KB)
Here’s another much simpler approach using Patt’s curves as the basis for an individual shark fin scale.
Shark Fin Demo-bb1.gh (18.1 KB)
This script produces a bunch of closed Breps arranged at the centers of a planar hex grid.
Version2 would offset each center point a small amount in a random direction, and then scale each scale a small random amount at that point. Finally, map the array onto the desired shape. I wonder how it would look on a boomer hull.
Thank you for your all reply. They helped me a lot:)
