I used in the base code of import rhino to revit in the website page.
now i want delet this mass from revit. how can do it?
thanks
thanks
There is a delete component, you can also unpin and delete manually if need be.
how i can unpin?
now the mass appear only in revit and i can’t chose it, It’s like frozen…
thanks so much!
Well, nothing worked for me and I transferred the file to a new file revit without the mass.
Can someone send me an updated transfer gh file from rhino to revit that work without problem?
thanks!
Guess the whole model is one direct shape. If you graft the output before it gets to the direct shape component, each object will be its own in Revit.
But it you put you definition here we can check that.
@yehmerm I’m still not sure what the issue is. Please be more specific and share screenshots, Grasshopper files or other resources so we can replicate the issue here. I opened the Revit model you shared and I can easily delete the mass either manually or thru a grasshopper definition.
If you are seeing an error in the Grasshopper definition, make sure the delete is the last step in the process and the element being deleted is not used or modified in other places in the definition
