Can you describe the workflow and intent you are trying to do? Inputs and outputs
A little background info: I have about 10 years of experience using Rhino, about 7 years with Revit, about 3 years of experience running pretty sophisticated GH scripts, and I have created some simple ones in the past. I’m exploring RIR to create definitions to speed up modeling tasks in Revit.
Using this definition I grabbed this geometry from Revit and put it in Rhino:
These are all types from a Cable Tray Family (that runs overhead in buildings):
The geometry in gray is the original output from the definition. I hand-modeled the orange geometry per project requirements.
These are no-fly zones that other trades must maintain unobstructed. The orange geometry will be the input to bring into Revit as a mass family (or any other similar family that allows quick manipulation using grips in plan view or 3D view by Revit users). See .3dm attached
Cable_Tray_&_No_Fly.3dm (4.1 MB)
You mention that you want “Full Parameters for manual manipulation”, as well as multiple team members. Is this a one off project or something you are going to repeat?
This work repeats. Every project needs clearance space for installation and maintenance of cable tray runs. The goal is to gradually develop definitions for more complex tasks, all project data and deliverables are mostly produced with Autodesk software, mainly Revit.
What is the size of the projects, roughly?
from 200,000 SF to 1,700,000 SF
All these factors will help guide appropriate usage of Revit as well as Rhino.Inside. Revit’s role. Thanks
I thank you for your help, Japhy. I apologize for the delayed reply.
