In-Place massing through Rhino.inside
Can Anyone help me with showing me how to construct an “in-place” mass in revit for a massing constructed through Rhino.Inside? I used the scripts in the snip attached, while it exports as a mass, i am not able to edit it in place!
Hi Nithin, The Revit API doesn’t have a method for creating in-place families. In the case above you can open the Revit Family created and slide things around if need be. Note that this would break the control from Grasshopper that you began with.
Thank you Japhy!
Hi Japhy, is there any chance to import the path curve and profile from rhino and create sweep in revit?
Hi @Ryan_Zhao
you can use Add Mass Loft Component which takes Rhino Profiles. But it only works in Mass Family environment.
