I have to rework a model where I filleted edges. Any way to delete filet or un-fillet? Also, you can see in the original portion, lines/edges define the filet. The additional section (made with Sweep1) the filleted edges is smooth. Why is that?
most probable way to work would be explode, then select the surfaces and rebuild with no retrim. this might at least gives you the intersections to rebuild the surface at your needs. EDIT: it didnt work at all with your file. sorry for the confusion.
sweep has the option to rebuild the cross sections, which would result in rounded edges, while one of the other options would keep the straight edges.
Nope.
In parametric, “feature based”, solid modelers, fillets are “features” that can be applied to corners. These features can usually be changed and modified by changing the feature parameters.
In Rhino, fillets are modeled surfaces, so there is no “feature parameters” to modify.
Hello - FilletEdge has an Edit option where you can go in and edit fillets that were added by the FilletEdge command, including removing the edges from the fillet selection. In your object only one fillet is editable though…
