Delete/Escape key Revit override
I’m using the latest RiR with Revit 2020. In previous builds Delete key in RiR was override by Delete function in Revit, but in Grasshopper window everything was working as it should.
Nowadays, both Esc and Delete keys are triggering Revit functions instead of Rhino/Grasshopper which means that I can’t delete geometry, components nor deselect them.
EDIT:
I checked it again, made some reinstalls, etc. and there is clearly a problem with the new build. 2019-12-30 14:44:44
I can’t even copy (ctrl + c) components on GH canvas or save GH file by keybaord shortcut (ctrl + s).
Thankfully, I still had some previous installers in my downloads folder and this problem is not existing in build: 2019-12-23 11:20:18. Unfortunately, I don’t remember if there were some other problems with this build but I must use it for now.
Maybe a good idea would be some changes in the download section. For example list with 5 latest builds with release dates
