tc1
(Tc)
September 23, 2019, 11:55am
1
I am not able to delete any GH canvas component while using it inside Revit (Rhino.Inside - WIP). Whenever I do it, GH goes on the background and Revit pops-up.
This applies to any component at all. I have tried FN+Delete and any suggestions I have found online, without success.
Help anyone?
y.schindel
(Y Schindel)
September 23, 2019, 12:20pm
2
no solution here, but I got a related bug.
The delete key (not Backspace) is not working in Rhino.
Typing the “delete” command does work.
TomWue
October 30, 2019, 11:08am
4
Since I updated last week and right now again I have the same issue in Revit 2019. I cannot delete, Copy/Paste, Alt-Drag-Copy in Rhino.inside and GH!
Is there any solution?
Edit:
I just realized, when I start a command like duplicate edge in Rhino , keys work in GH…
kike
(Kike Garcia)
October 30, 2019, 12:14pm
5
This works in Revit 2017, 2018, and 2020, but is a problem in 2019.0.
I recently update my Revit 2019.0 to 2019.2.2 and seems is now fixed.
Here you can see the Updates history of Revit 2019, and here what is new in 2019.2.2
@kike
I am using Revit 2020.2 and I have same issue. Can not delete GH components.
I am trying to delete List.Item but unable to do so. I can from Edit.
Any help will be appreciated.
kike
(Kike Garcia)
January 9, 2020, 11:45am
7
Hopefuly next Tuesday release will fix this.
The problem was the previous fix didn’t fix the Delete key on Rhino.
I tried to fix this in RiR but the fix needs to be done in Rhino, and it’s done.
The new Rhino WIP that use to be released every Tuesday will include that fix.
Sorry for the inconvenience this week.
Hi @michaldengusiak ,
Did you find a workaround?
I have the latest version of Rhino.Inside and Revit 2020. The issue remains.
Hi, it is not fixed yet … Hopefully will be soon
kike
(Kike Garcia)
January 29, 2020, 9:21am
11
The fix is available.
You will need to update Rhino WIP and Rhino.Inside Revit .
djordje
January 29, 2020, 11:29am
12
Hi @kike ,
I have the same problem on Revit 2019.0
I have Rhino WIP 7.0.20014.11185
and Rhino Inside from 21.01.2020.
Does this mean that with the newest release of Rhino WIP, this issue will go away on Revit 2019.0 as well?
Or is it necessarily to update to 2019.2 in addition to having the newest Rhino WIP?
kike
(Kike Garcia)
January 29, 2020, 1:33pm
13
With the last release should work on any version and on any window, this includes Rhino, Grasshopper and PythonEditor.
In your case you need to update Rhino and Rhino.Inside Revit.
opnicuser
(Opnicuser)
March 2, 2021, 7:44pm
15
Using Revit 2020.2. Downloaded and installed RIR today (3/2/20) and using Rhino 7 Commercial. Based on this thread it seems to be solved, but I’m still having issues.
