Default.Transform pop-up too big
Are there new UI settings that control the size of it? Also, menu bar is missing to temporary pin and do adjustments like copying 1D-Scale into the floating pallette.
Just copied the 1) settings-Scheme_Default.xml and 2) window_positions-Scheme__Default.xml from Version 7 into the Rhino 8 settings folder. Maybe this evoked the bug?
Thank You!
Hi Hannes,
There is another thread related to the redesigned pop-up toolbar here:
Thank you Mike!
@MikeM I figured out the scaling but I just can’t activate a toolbar so that I can dock it temporarily and start to customize the popup toolbar with copying commands, as said e.g. Scale 1-D.
The upper bar from v7 is missing.
The popup menu doesn’t dock anymore. :frowning: To edit it, you have to open up the toolbar that lives within the popup menu separately.
Why? makes no sense. I find it a downgrade. It was so easy. I wish the old behaviour back :slight_smile:
mouse click images missing in v8
Popup Toolbar: Right click long delay until tool active
I don’t see a delay here when right clicking in a tool of the popup. Also it’s hard to see it in the video how long of a delay it is.
thanks, I added RH-73337 Mouse icons missing from popup toolbar mouse-over
