Cycles bug
@nathanletwory,
just found a major bug in the current cylces built for rhino. If i assign a custom 360° Environment it shows up as expected. Once i assign a material or enable a render setting like eg. Focal Blur, the environment is not displayed anymore. If i switch the backdrop back to eg. SolidColor or Gradient and then revert to 360° Environment, it shows up again.
Installed version is 6.0.17003.21561, 03.01.2017
Add: changing from draft quality to final quality is crashing the WIP, i’ll send in the error report.
c.
Hi Clement - thanks, I see this here as well.
https://mcneel.myjetbrains.com/youtrack/issue/RH-37368
@clement, I have created a fix for this, I hope it gets into the next WIP.
I couldn’t repeat the crash on changing to different quality setting.
@nathanletwory, thanks. I will keep on testing.
btw. speedwise i see a large decrease currently with the testscene i’ve send via PM. I hope this will improve with future versions of cycles.
…and thanks for getting OpenCL up and running again :wink:
c.
RH-37368 is fixed in the latest WIP
