I like it!
The smooth shadows are fast and responsice and great for the realtime sunstudy!
Great work guys!!!
Shadows are still messy with blocks so I have to explodeblock to avoid the shadows from going all over the place.
I like it!
Great work guys!!!
Here’s another bug:
I made a “physical sky” environment so I can have an auto updated skycolor that is driven by the sun, but it doesn’t show up in the rendered mode as I can’t assign the “use application settings” to the display mode, it jumbs back to “use render settings” and if i try to alter the rendersettings to use the environment as a “360 environment” then I get a big black 2D cirlce showing through the ground plane.
On my Win 10 dual Xeon + Quadro 4000 system the render display mode turns all geometry completely black, even after a reinstall of the WIP, anything I can do?
Same for me…When I switch to rendered mode, geometry is completely black. Even when I turn on the sun or other lights…
Is this a solid color, or some sort of gradient?
