Curtain walls' corner mullions on VA 3
Hi all,
I was wondering if VA3 will have the functionality to solve corners for curtain walls. As for now, the curtain wall tool does not draw corner mullions.
I’ve started this thread (CurtainWall corner mullions) and there seems to be a workaround with columns on corners, but still looks weird in 3d and in 2d documentation.
Any idea if this will be on VA3?
Thank you
Hi @biz,
This feature is still awaiting… so I am not sure if it will be ready for VisualARQ 3. In the workaround you are using, I see you have some parts of the column overlapping with the curtain wall; maybe you can fix this using the vaSubtractSolids command.
Thank you for your reply. I really wish we can have this item. Regarding your suggestion, it’s possible but as I have many, many CW the task it’s a bit daunting. We’ll try some GH see if it can be done.
Hi @biz, as mentioned here (CurtainWall corner mullions - #7 by fsalla), in VisualARQ 3 we have added an option to calculate joints between curtain walls.
