Hi! I recently switched to Rhinoceros 7 and everytime I try to copy something with the ctrl+c ctrl+v command it takes a really long time and sometimes even freezes the program for a while, even if it is just a simple cube in a fresh new file. Didn’t have any problems in Rhino6 and the command “_Copy” works just fine. Please, is there anything I can do to improve this?
Edit: ctrl+c seems to be normal but ctrl+v is slow and sometimes freezes.
This has been addressed in the latest service release candidate. If you want to try it, go to Options>Updates and Statistics, set the update frequency to “Release candidate” then hit the “Check now” link. Download and install the latest RC and see if it’s not better.
Does this happen with any file, any object or is it a specific object or file causing the problem? Can you run SystemInfo in Rhino and copy paste the results here?
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 980M (NVidia) Memory: 8GB, Driver date: 6-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\Beam\App\RHINOBEAM.dll “MKS BEAM” 1.7.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.2.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\OctaneRenderForRhino (f109bd23-4cf3-4c0b-9f83-06be474b0152)\4.5.0.115\RHI Installer 6\Rhino 6.0\x64\OctaneRenderForRhino.rhp “OctaneRenderForRhino” 4.5.0.115
Maybe first try disabling the first three non-standard plug-ins temporarily and see if that fixes it.
I see the Octane plug-in is made for V6, I don’t know if that is a problem or not.
