Ever since using R8, to paste objects between instances of Rhino the system requires two presses of ctrl+V to actually paste the objects. Clearly not a major issue but starting to get annoying.
Is there some weird setting I’m missing to solve this problem or is this a known issue that needs developer time?
It’s not a dodgy keyboard, it isn’t a miss-hit of the keys.
It’s not something that I seen on my systems and I don’t recall having had other reports of this.
When you now run Rhino 7 on that machine, that still works with a single ctrl+v?
Please run the Rhino SystemInfo command and copy-paste the output here.
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
.NET 7.0.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
I deleted ctrl+V keyboard shortcut a while ago because I paste a lot of points from excel. Ctrl+V shortcut was not allowing this functionality to work.
It isn’t the keyboard, crtl+V works perfectly in R7. Dare I say that the current pasting situation, for both objects and lists of points, is a regression in functionality from R6/7 and undesirable, so it should be fixed.
@jeremy5 … It needs to be “immediate”. If I flick between instances of R8, ctrl+V needs to be pressed twice again to enact the paste. But this is rare as I usually paste the objects I need straight away.
