Hello, im having some trouble to make the Copy, paste or cut commands work on a certain file in rhino 7, every time i CTRL C or V or X, rhino stops responding forever and eventually i have to finish the process manually,
Is there a fix for this or some explanation on why it could be happening? The file is kind of big, (650 MB) but i dont think it should affect this command, also it worked perfectly previously
Hi Daniel -
What is “forever”? Does the Windows Task Manager show that Rhino is still working?
Does it happen with any object in that file, or do you need to select multiple objects?
Please run the Rhino SystemInfo
command and copy-paste the output here.
Actually it just freezes clicking anywhere makes it enter the “not responding” status. But i did the experiment and waited when it froze and eventually it just stops responding, showing in the task manager that is not responding as well. Happens with any object, any object that I try to copy to the clipboard. I have the theory there might be something wrong with my memory that makes it crash whenever rhino tries to access the clipboard, but this happened previously on another file and i ended up making an export of the geometry i wanted to keep and on that new file the error didn’t happen… until it happened again, and its constant , 100% it will crash if i try to use those commands. Here’s the output of systeminfo
Rhino 7 SR35 2023-12-12 (Rhino 7, 7.35.23346.11001, Git hash:master @ 6916542aa86609e2c43094fedcff51a3bd3c5723)
License type: Commercial, build 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.18363 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-3-2022 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2023
Driver Version: 31.0.15.3742
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
D:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23243.1639
D:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.35.23346.11001
D:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
D:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.35.23346.11001
D:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
D:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.35.23346.11001
D:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
D:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.35.23346.11001
D:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.35.23346.11001
D:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
“Not responding” doesn’t mean it’s actually crashed, it’s just busy. When it actually crashes, it (should) generate the popup saying that it’s crashed.
Copying and pasting is exactly the same operation as exporting and importing a file, so I dunno if there’s something wonky in it causing loading times to go to the moon…?
Your video drivers need updating.
Hi Daniel -
What happens when you disable Enscape in the plug-in manager and restart Rhino?
Hi Wim, sorry for the late reply,
It still happened after disabling enscape. But i noticed something in this time: Importing complex meshes from google maps has been part of my workflow recently and when the embeded info starts to get large (from 500mb more or less) is when the ctrl c or ctrl x commands start to add up some loading time. Haven’t got the chance to test this for sure, but noticed the behaviour on a completely different machine and file. Will update if I get to confirm it for sure.
Hi Daniel -
I’m still not clear on what is actually happening. This sentence seems to imply that it eventually finishes?
If you have something that is reproducible on several machines, you could upload a file and we could try to see if anything is going on.
