Hi group
is it possible to create surface textures from photos or bitmaps and apply them round a surface for 3d printing?
i.e if i had a cup and on the outside face of the cup i wanted to add a 3d texture taken from a photo is it possible?
A
Hi group
A
I think this is the tutorial you’re looking for:
you can use Displacement map / Normal Map to do exactly that
great thankyou.
i think my initial issue was size? at first i couldn’t see anything but playing with settings i have started to get results.
i am assuming the bitmap size is relative to the model size, is there any guidance on sizing?
A
Hi Adrian -
No, you’ll have to scale that to fit your requirements.
if you want to be quite precise, basically set the displacement map with the same Channel map as your UV Texture. here is the example of displacement checkerboard with dimension of 1cm x 1cm x 0.5cm.
then your displacement should match with your UVW map texture.
note: i dont recommend doing this way for 3D printing. easier to do is to just model the pattern.
