I want create a new Scheme
I’ve read this link
http://wiki.mcneel.com/rhino/schemes
So, I create the Scheme with a shortcut, but I want define the disposition of the views as three views and renderer all views.
This configuration isn’t saved in the scheme, and I’d like , when the user run the shortcut, Rhino will be loaded with this configuration
Thanks
dale
(Dale Fugier)
May 28, 2014, 8:37pm
2
Create a template file that is configured the way you want - 3 view, rendered, etc.
Then, set this template file to be the default template file (Tools -> Options -> Files)
Hi again,
I’m trying add a new tab and a new button in the new scheme.
I’ve created a new rui file with the tab and button, but when I run rhino with the scheme this rui isn’t loaded
I’ve read that I need override the default rui, but I’m doing an installer, so the path
C:\Users<user>\AppData\Roaming\McNeel\Rhinoceros\5.0\UI folder
the parameter is different, and I can’t override the default rui.
Bye
dale
(Dale Fugier)
May 29, 2014, 3:46pm
5
If you give the RUI file the exact same name as the plug-in RHP file and install it in the folder containing the RHP file (or its parent folder) Rhino will automatically stage it in a writable location and open it at startup.
Does this help?
