However, the RUI file does not get installed; the plug-in (RHP) works fine however. To install the RUI file, the user now has to navigate to C:\Users{user}\AppData\McNeel\Rhinoceros\5.0\Plug-ins{plugin-folder}\Rhino\5.0\Common in the Tools -> Toolbar Layout dialog to get it installed.
Is this lack of RUI installation intended behavior or am I doing something wrong? If it is intended, I think it would be more user-friendly to directly install RUI file(s) if present in the Common folder.
Yes, they’re packaged in the same file, and they RHP and RUI have the same name. I have put the RUI in the Common folder as instructed on the page referenced in the OP. But I’ll try to put it in the same folder to see how that works out.
Ok, it is working when the RUI file is in the same folder as the RHP file. It is not working when I have the plug-in in Rhino 5.0\x64 and the RUI in Common\
You may want to update your documentation at http://wiki.mcneel.com/developer/rhinoinstallerengine/authoring to reflect this situation.
@brian my rhp and rui file are in the same folder sharing the same name - but on first install rhino copies the rui file into the roaming McNeel folder and references the rui file there from then on.
My guess is that the RUI file gets copied to the roaming McNeel folder because then the user can make changes to the toolbars without affecting other users on the same system.
In our case, however, we managed to reference the installed RUI file directly: we have since switched to an MSI installer that also installs a RUI file. When this file is installed, the MSI installer will append the location of the RUI file to this multi-string registry key:
This is by design - we copy the RUI files into a well known and writable
location for the user. It is possible for RHIs to be installed into
read-only locations, making it difficult for users to rearrange and
position their toolbars.
Can you explain what the downside is for us doing this?
Brian
Brian Gillespie
Rhinoceros Development
Robert McNeel & Associates
