Crashing when working with layouts
21-03-23
Hello, I’m new to Rhino, currently deep diving into tutorials before I start soon on a project on which I’ll need to be using it.
Encountered a frustrating problem today as I learn about layouts.
Rhino doesn’t want to open existing layout pages - circle of death then crash. If I create a new layout, Rhino also crashes if I try to delete it.
I am up to date with versions.
System Info etc attached
Help please
Peter
RhinoDotNetCrash.txt (4.1 KB)
System Info report.txt (2.9 KB)
Hi
There are no crash reports in the system associated with your email address.
When the cartoon Rhino and the deflated beachball crash reporter tool comes up, add your email address and a description of what you were doing when Rhino choked.
For now, please run the System Information command from the Help pull-down menu, and return that information in a reply.
Thanks
Thanks John,
I have attached the system info.
It’s not crashing, just gives me the grey screen ‘wheel of death’ for more than 10- 15 minutes before I have to close it manually.
It happens when I try to open an existing layout tab (screengrab attached)
And I am simply unable to open another file (screengrab attached)
Appreciate your help
Would it help to send the file itself??
Peter
210323_System Info report.txt (2.9 KB)
Your display drivers are very old. See if updating those resolves your issue.
Thanks Gijs.
I have updated drivers, unfortunately same issue.
Also followed John Brock’s advice on thread: Soooo, you bought a laptop with hybrid graphics and rhino doesn't run right. READ THIS.
Could it be an issue similar to Rhino 7 crashing like hell when activating or trying to work with layouts? ??
Cheers, Peter
Hi Peter, in that case, can you send again _systeminfo and post it back, and also send the model. You can upload it here. Please mention this thread and @ mention me here once done so I can see if I can repeat the issues you are seeing.
Additionally what you can do is make a memory dump and send that (will be a big file, so pls use 7-zip to zip it then upload it to the same page).
To make a memory dump, see this page
Hi Peter -
When you start Rhino from a factory-default template and leave that empty, are you having issues with creating or deleting layouts then?
From your screenshots, it looks like Rhino is working hard on creating display meshes for viewports in a technical display mode. For some objects, and on some hardware, that can take a very long time…
good catch, that might be it
Thanks for sticking with me on this Gijs and Wim
I have uploaded files and dump per our instructions and attached is the system info
Look forward to hearing further
Cheers Peter
Rhino-System Info.txt (2.49 KB)
hi @peter_gideon a few things that catch my attention:
Physical RAM: 7.9Gb (this is a weird number but also very low)
Primary OpenGL: NVIDIA GeForce GT 650M (NVidia) Memory: 4GB, Driver date: 12-18-2017
still shows a very old driver
Did you try @Wim 's suggestion already?
@peter_gideon I think there is still a newer driver you could try: Geforce Driver Results | NVIDIA
I am also getting frequent random no warning crashes in layouts. There is no clear pattern when it happens, just always in layouts. Rhino just closes in a flash.
Summary
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Educational, build 2023-09-05
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 96Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 8-14-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.13
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 7-24-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2023
Driver Version: 31.0.15.3713
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.2.0.0
C:\Users\Primoz\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.38.73\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.73.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.31.23\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.31.23.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
Hi Primož -
Is there a crash reporter after Rhino has closed?
Have you tried Rhino 8 to see if that behaves the same way on your system?
No, rhino just closes in a flash. I haven’t, and I’m currently unable to try it as my project is based on plugins such as VisualARQ. The crash happens completely at random, sometimes multiple hours between crashes. Sometimes it crashes when the moment I switch to a layout viewport, at other times it happens simply when navigating the layouts. Currently, I don’t have the time to spend hours testing the issue in R8. Maybe someone else who is experiencing the same issue finds this thread and can file a report as well.
