Having an issue for the past couple of months where Rhino will sometimes crash when clicking in the text edit box. It most commonly happens when working in layouts, whether in blocks or otherwise.
Haven’t figured out a way to force the crash but is often times repeatable when reopening a crashed file. I’m on 6.9.18253.21101.
They should all be sent under the same email (stan@substratefab.com) with files included. The actions leading up to the crash are always consistent (activating text edit box) even if it doesn’t happen every time…
Right now I’m wondering if it has something to do with annotation styles. Will keep an eye on which specific text causes a crash.
@stn - Just to clarify since there’s a lot of crap written in that bug report -
The reports you sent and the help you offered made it possible for us to find and fix the specific thing that was causing your crashes.
When we could finally pin down the steps to trigger the crash, thanks to your reports, it was clear what was wrong and possible to fix.
Thanks.
