Crash when trying to edit annotation style from linked (DWG) block
I work a lot with inserting DWGs as linked blocks. These DWGs often have embedded annotation styles. These annotation styles appear in the list of annotation styles in Rhino, but when I click an annotation style from an external DWG, Rhino instantly crashes. This happens every time. I don’t mind not being able to edit externally referenced annotation styles, but I sometimes click one of these annotation styles accidentally.
Is this bug something that is being worked on? It’s very annoying.
Hej Agnes -
I’ll need some help reproducing that behavior here.
Could you start by running the Rhino SystemInfo command and copy-paste the result here?
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Commercial, build 2022-11-22
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.101.1122
Secondary graphics devices.
NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 6-22-2022 (M-D-Y).
ATTENTION:
An integrated accelerated graphics device exists and is attached to a monitor, but it’s not being used by Rhino.
  • Recommended: Use Windows’ Display Settings to configure one of the other monitors to be the “Main Display”.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 30.0.101.1122
Driver Date: 11-15-2021
Driver Version: 30.0.101.1122
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
C:\Users\91alu.WHITE\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.3.0\7\Fologram.IO.Rhino3d.Win7.rhp “Fologram for Rhino” 2020.3.3.0
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.4.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.36.157\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.36.157.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.9.6\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.9.6.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
Hi Agnes -
There’s something wrong with the configuration of the display devices on your machine.
I would first reboot the machine and check if all updates for Windows 10 are installed. Then try a clean install of the drivers using the following recipe:
Hmm, OK, this crash happens even when I’m not connected to an external monitor. But maybe the drivers thing is relevant for the crashing anyway.
