Linked Block DimStyles causing crash in Rhino 7
I’m running into some unexpected behavior when working with blocks that have annotations in them.
If I insert a block, for example a Title Block, with annotation objects, everything seems fine if I use Embedded + Linked, or Linked with the Layer Style set to Active.
However, if I use a Reference Layer Style:
And then go to the Annotation Styles:
I see them in the Drop down on the left, but if I click on one, to see the settings, then Rhino 7 crashes without any warning or prompts.
If it is either of the other two scenarios (Linked w/ Reference Layer Style OR Embedded + Linked) then it seems to work fine, though there is a noticeable pause as it tries to load the Annotation Style window the first time.
The crash does still save a RhinoDotNetCrash file to the desktop:
[ERROR] FATAL UNHANDLED EXCEPTION: System.InvalidOperationException: Dispatcher processing has been suspended, but messages are still being processed.
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
[END ERROR]
Can certainly use the other block settings for now, but seemed important to note.
I think it would be helpful if you posted the results of running Rhino’s SystemInfo command and a .3dm file that demonstrates this.
Thanks for the reminder!
Here’s a model that simply has 1 leader in it, with a dim style copied from one of the Built-In styles.
StyleFromDefault.3dm (30.8 KB)
System Info:
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Commercial, build 2022-01-10
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 10-28-2020 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Users\krahimzadeh\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
Thanks for reporting, i was able to reproduce and will get it on youtrack.
Just chiming in to say that I have this issue as well. Instant crash when clicking on a referenced block annotation style. Any updates or news regarding this? It’s quite frustrating when I accidentally click the wrong style and crash the software…
